RCU Forums - View Single Post - Balsa USA Citabria Pro Build Countdown
Old 11-10-2010 | 08:00 PM
  #71
R-Duhb
Default RE: Balsa USA Citabria Pro Build Countdown
<span style="font-size: small">Hey Rye,
I'm back after several days of no building. Now I'm trying to join the wing panels to the center section. I need you to take a look at page 15, step 3 in the manual. It's the section directly beneath photo 50. Did you reallyblock up the ends of the wing only 0.5"? In order for myW2 ribs to be flush on both sides of the dihedral joint I had to block it up about 1".I double checked both wings with the dihedral gauge and I made sure the outer ribs of the center section are square. So if it's actually 0.5", then I have a problem. There is a fair amount of gap on the top of the wing at the mating ribs.</span>
