RE: Balsa USA Citabria Pro Build Countdown
hey r-duhb
i heard that they change the degree of down and right angles and maybe other things ,i shot off a e-mail to them to find out as for the wing i cant join them together right now but ill let you know 85 degree is not very much of 90 degree ,i been working on the body hear and there going to take a break got to get my sons trainer back in shape we loss radio signal from a futaba 2.4 6 channel had to send it back to them a bad cp board the plane went down in high grass a little damage [:@] but easy fix getting the radio back on friday sat flying day ,hears the work so far on the body see u later ,rye
ps if u have to make a new rib for each side and glue it on the wing roots and reshape them i an going to fit them to the center section at 85% i am going to block up the tips so the root is at 85% to the 90% center section [X(] we well see if that works?
