RCU Forums - View Single Post - the reason to install a kill switch
Old 11-12-2010 | 12:16 AM
Flyfast1
Default RE: the reason to install a kill switch
ORIGINAL: aussiesteve
Fact is, there is really only one reason that a Throttle kill such as an optokill is ever needed. and that is because of human error (Bad throttle programming, Bad linkage installation, Bad engine installation, poor battery quality, poor receiver installation - the list is near endless on how we can get it wrong on our toys). That video shows me a human error of some sort - asssociated with the throttle setup not allowing the throttle to close completely. Maybe the linkage shifted after takeoff or maybe it was not right in the first place - could be a number of things but they all point to human error of some sort.
As has been pointed out - they don't work on most glow engines.
I prefer to use them on my big toys so as to minimise the engine damage when I make an installation or setup mistake. Having said that, not all of them have got them installed.
My experience is that radio failure (human or electronically caused) will usually result in a ''positive engine stop'' pretty quickly. Or a softer one if the failsafe is set to bring the throttle back to fully closed.
What if the throttle servo fails in flight? In that situation a throttle cut/down function or trim down won't help, but an ignition kill can, so it can help in situations where there is not human error involved.
-Ed B.
