RCU Forums - View Single Post - YS .91AC Idle Issue
Old 11-12-2010 | 01:19 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: YS .91AC Idle Issue
I was running an APC 15X7 on mine. Never hit it with a tach but level full throttle would rip the prop. Fuel was Powermaster 20/20. Properly adjusted any engine should idle as long as you want. I stand by my first suggestion, fuel it up with fresh fuel. If you do and don't see an improvement after adjustments I will buy lunch next race. My guess is you have the needles set more open then what would be considered normal. Tell tale sign that the fuel has moisture.
