RE: Gas Engine Oil Mix
the 3 oils that seem to be generally recommended are as follows
Stihl ultra
ECHO power blend
red line 2 stroke
really any 2 stroke oil works well enough but ya might as well use the best you can get, since its pretty cheap stuff, and regular gas 87 octane is all you need for the DLE engines.
why would you think that glow fuel would work in a gasoline engine, glow fuel is 20$ a gallon Gasoline is 3.20
OP look in the gasoline engine forum there's lots of info there on the DLE line from the 20 on up in size
