switch harness question
Instead of purchasing a super switch why not create a semi redundant system by adding a second switch. The reason I say semi is because you are using one battery if you optioned to use two batteries and two switches then you would have a more positive redundant system. I use this system in all of my planes by creating a Y harness soldered off of the single battery.
Randy
