RCU Forums - View Single Post - The Pepsi Challenge for Covering Balsa with LS
Old 11-13-2010 | 07:50 PM
2walla
My Feedback: (10)
Default RE: The Pepsi Challenge for Covering Balsa with LS
Can I suggest that you make a couple of stress risers in your test pieces- put in a couple of glue joints both parrellel and perpindicular to the grain so that you can do some flexure testing to see if it cracks over the joints. I used to paint my quickie 500 racers and tried several things to seal them up- the best thing ended up being mod podge thinned out a little bit with water. It held up great- you should try a couple test pieces with it..
