RE: Balsa USA Super Cub Build
I have the Electro Dynamics nav light system Mark.The white tail light is an option,so I made a seperate landing light setup that will be flap activated.I'm going to use the E/D landing light as a tail nav light.Mark if you could pickup a good used Z-62 that would be perfect balance wise at least.I'm using a DLE 55 and cannister setup.The cannister tunnel doesn't leave much room for the pilots legs but i'm not to concerned about that.I'll also be adding the Balsa USA floats.
Steve
