RCU Forums - View Single Post - DA 120 weight
Old 11-14-2010 | 07:45 PM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: DA 120 weight
ORIGINAL: Forgues Research
ORIGINAL: JoeAirPort
4 lb 15.4 oz
Thanks but is this including the ignition module , spark plugs, prop mounting bolts....
Thank you
Roger
Ahh... Roger....
I told you in my first post that it didn't have the ignition module....
If you look at the pic you can see that the sparkplugs, prop mounting bolts (you can actually see one) and washer are installed so all you need is the ignition module weight and/or what ever type exhaust you want, or maybe somebody did it for you over on FG instead of making you search the thread 'cause I'm certainly not going to pull the module out of the Compy to weigh it for you....
