RE: World models 80 inch p51 engine advice
Thank you to both of you for the replies. I've been wondering how this engine would fit in this plane. Seems like its as good a match for this plane (including weight - doesn't take much to balance the plane) as I thought it would be. My 2300 takes about the same amount of weight to balance as the 120g (4.2 ounces) benjret used.
3136 -I would be very interested in the rpm you get with the props you use with that canister muffler. Seems like a good solution to dealing with the noise limts there. About the same cost as a wrap around muffler. Does the canister act like a tuned pipe? How did you pick that size canister?
Thank you
Ed
