ORIGINAL: nitro stan
ill pull it off and see what happens.
im gonna get new tires.
i went through the front end and set the steering and camber links with a caliper, i dont have a set up station so i dont know how much camber it has,
set the rear links the same way.
Go here for tires: raikoudrifttires.com
Calipers are the next best thing, if you don't have a set up station!! You can check camber with a protractor, or anything with a reliable right-angle.
You also don't HAVE to set front and rear same, if you don't want to. I see folk set camber for only the front wheels, but keep rears at "0", others, camber all the way around, and some, none (I fall into the latter category). It's up to you.
