RE: Redcat Racing Rampage MT V3- Let's review UPDATE: 2/24/11...gone...
After installing my Spektrum receiver and setting the throttle up, I noticed the steering servos are fighting each other when the remote steering bias is centered (with no L/R offset). The steering servos should be quiet when the wheels are straight and the remote bias is centered. Instead, the servo motor's are making noise; it's the same sound as when you hold a servo arm and attempt to turn it by hand when the servo is powered up. This means that one of the steering servos is pushing against the other when the truck is just sitting with the wheels straight. I will measure out the dual steering links and make sure they are the same length.
