RE: K & B engine
There should be a brass disk oposite the high speed needle valve. The disk is moved with a little ecentric screw at the 12 o'clock position. The disk is attached to a tube inside of the spray bar that has a cats eye opening that is the adjustment for low speed and mid range. The adjustment range is quite small. I don't remember whick way is lean or rich. Go to MECOA.COM and look at the user guide for the .45 Sportster; it will tell you how to adjust it. Run this bushed engine with 4oz/gal of castor and 10-15% nitro and you will have a long lived reliable engine. Make sure the o-ring on the disk assembly is snug.
