RCU Forums - View Single Post - Help in running a 4 stroke inverted
Old 11-17-2010 | 08:31 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Help in running a 4 stroke inverted
I have mounted many 4-strokes inverted and it rarely causes any problems. I run my regular 15% Cool Power.
About the only problem that can occur is the carb location. If the carb is too low, a full tank could cause the fuel to siphon and drip out of the carb. The trick here is to not fuel it up until you're ready to start the engine.
