RCU Forums - View Single Post - Help in running a 4 stroke inverted
Old 11-17-2010 | 12:34 PM
ChuckW's Avatar
ChuckW
Default RE: Help in running a 4 stroke inverted
Ihave always had great luck with inverted 4-strokes. the only exception was an OS FL-70 which was their lower-end 4-stroke and had an air-bleed idel circuit on the carb. If I had lowered the tank, it likely would have worked OK though. Everything else has worked great.
