RCU Forums - View Single Post - Pull-Pull on throttle
Old 11-17-2010 | 05:19 PM
captinjohn
Default Pull-Pull on throttle
I am wondering how pull-pull would work on my DLE 30cc throttle set-up? I do not have enough ny-rod to reach. I do have some high grade tubing and was thinking of running super heavy braided fishing line through the tubing to throttle arm. I was going to use the arm on servo to pull the line & let the tension on the carb spring to pull back.
Also what I do not like about ny-rod is that it changes length with temperature. Capt,n
I may just try it...if it seems like any problem I can replace it.
