RCU Forums - View Single Post - Not Actually A Beginer
Old 11-17-2010 | 08:11 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Not Actually A Beginer
Futaba has a much simpler binding process.
There is a tiny button recessed between the two Receiver antennas.
Turn on the Transmitter (Tx), bring it to within a meter of the Receiver and turn the receiver (Rx) on - A green LED will be flashing on the Rx. (Note: if you turn on the Rx with no Tx turned on, the LED will be red)
Push and hold the tiny button on the receiver for about 5 seconds (You will need a toothpick or something similar to push the button with).
When the LED on the Rx stops flashing, your Rx is bound to your Tx.
