ORIGINAL: captinjohn
Well after cooking my wife some Fresh fish (Steelhead) on the oudoor grill...I hooked up the pull-pull on tthe throttle. It is just about a strait line to servo...but used about 10 inch tube for it to run in. I worked it by hand first at servo end....super smooth. I then hooked it up and tested it with TX. Seems real nice.
Hi John,
As long as the line is in a straight run, I cannot see why this wouldn't work quite well!
There are some good leaders used on fishing lines that are metal. That woudl also work.
Or an offcut from a pull-pull wire
