Shorts Tucano T1-120
To Nitro tech support:
Gentlemen I have purchased the Tucano 120 and am in process of assembling/building. The stab as molded in the fuse is 5 degrees positive incidence (5 degrees "up" stab and elevator). Please check the design specs and verify if this is correct, I can modify if necessary.
Also I was surprised to find the model is retract-ready, which is what I prefer. It might be helpful to others to mention that in the advertising.
When finished I will post a build thread. I look forward to your response.
