ORIGINAL: pizman
When I measure the Blind nut locations on the firewall they are not centered (left side has 1/2'' more than right side), shouldn't the engine be centered on the firewall?
The engine is off set to one side so that the end of the crankshaft will be centered in the cowl. If the plans/instructions show the engine mount set this way then it does have right thrust built in.
