RCU Forums - View Single Post - Pull-Pull on throttle
Old 11-18-2010 | 11:22 AM
av8tor1977's Avatar
av8tor1977
Default RE: Pull-Pull on throttle
ORIGINAL: aussiesteve
I started leaving the throttle springs connected on all of my engines about 2 years ago. Partly because I was too lazy to disconnect them (It does take about 2 seconds after all) but mainly because it gives me a shutoff when I make a mistake and have a linkage disconnect (which ironically hasn't happened to me on an engine that has the spring connected). I don't know the exact load figure but I do know it has made absolutley no difference to the number of flights I get in per flight pack charge.
Actually, thinking about this since reading the OP. This method could be an interesting way around some of the side carb engines that are difficult to align a throttle rod to a servo. Maybe some fishing rollers with a cable to change the direction of the pull pull
Go on captin - you know you want to experiment more - this is a hobby after all
This was why I asked. I have some throttle cable assemblies I saved off of various yard equipment machines that have a nice swept 90 degree brass fitting on the end. If the servo amp draw is not a problem, they would be ideal for carbs that don't line up with the firewall for the throttle hookup. I have used 90 degree bellcrank setups before, but that always introduces a bit of slop in the hookup no matter how carefully you try to do it....
AV8TOR
