RCU Forums - View Single Post - Pull-Pull on throttle
Old 11-18-2010 | 11:52 AM
Teachu2
My Feedback: (133)
Default RE: Pull-Pull on throttle
With a true pull-pull (two lines under tension) you would be placing a side load onto the shaft connected to the throttle arm. Add the vibration present in the motor and you might end up with excessive wear, with the debris going right into the engine. I wouldn't do it.
