RCU Forums - View Single Post - Pull-Pull on throttle
Old 11-18-2010 | 01:34 PM
clivemc
Default RE: Pull-Pull on throttle
ORIGINAL: av8tor1977
I keep meaning to hook up a throttle like this, and then load test while the servo is pulling full throttle against the spring to see what the servo current draw is, and if it is excessive. Has anyone done this??
AV8TOR
its no different to having the spring resisting a solid pushrod. I did test this once, cant remeber what it was but it was so small it wasnt worth remembering
