ORIGINAL: captinjohn
I am wondering how pull-pull would work on my DLE 30cc throttle set-up? I do not have enough ny-rod to reach. I do have some high grade tubing and was thinking of running super heavy braided fishing line through the tubing to throttle arm. I was going to use the arm on servo to pull the line & let the tension on the carb spring to pull back.
Also what I do not like about ny-rod is that it changes length with temperature. Capt,n
I may just try it...if it seems like any problem I can replace it.
nyrod does change length - all be it very little. BUT i have seen a gas engine using nyrod that setup in the cold workroom that would not cut off when used on a hot summers day! and it worked first thing in the morning. that is why i dont rely on throttle cut but also always have an opto cut off, causeI do use nyrod sometimes if im looking for an easy way out to setup difficult linkages
