RCU Forums - View Single Post - Hitec Spectra Module Potential Problem?
Old 11-18-2010 | 04:00 PM
A.T.
Default RE: Hitec Spectra Module Potential Problem?
ORIGINAL: fizzwater2 spectra 2.4G modules have to be modified?
Negative, but they should be updated from time to time so as to take full advantage of the ongoing enhancements relating to the telemetry. e.g :
- <font color="#22229c">Low Battery Warnings - Minimum settings recommended</font>for both the Aurora TX &amp; Spectra 2.4GHz module - which are set separately..
Telemetry - Instruction Sheets &amp; User Guide.
Telemetry - Battery Voltage via SPC for EP Models
Telemetry - Flying Range
Telemetry - HTS-Voice Telemetry Voice Announcing System
Telemetry - HTS-Navi AFHSS 2.4GHz Wireless USB Telemetry Receiver
Telemetry - Range test Using Segway &amp; GPS - Video <font size="1">- Remarkable 2100+ft not only through large obstacles but also with Heli sitting in ground effect.</font>
Telemetry - Screens &amp; Displays
Telemetry - Full installation in Skylink 50cc - Video( 6 min 29 sec)
Telemetry - Screens &amp; Displays - Video
Telemetry - Download Demo 2D Graphic Flight displays of an actual flight. <font size="1">NB: GPS updates every .5 sec and will be fairly accurate for level flight but not dive speed since it is using ground coordinates for the calculation.</font>
Telemetry - Compatibility &amp; Open Source - status
Telemetry System - Spectra Pro installed Alternate TX Connections.
more at
Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips.<span style="font-size: smaller"> {Individual Links often updated}
</span>Regards
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
