RCU Forums - View Single Post - Himax 6330-F3A Pattern Motor
Old 11-18-2010 | 06:58 PM
  #161
woodie's Avatar
woodie
Default RE: Himax 6330-F3A Pattern Motor
There a few things that can result in lower rpm, but the most obvious is batteries that cannot maintain voltage under heavy load. You said the batteries are 4000mah, but what C rating?
A few other things that can effect rpm are timing of the ESC, is the throttle end point set so the ESC see 'full throttle'.
Woodie
Team Acme LG
