RE: Engine Mount Reposition and Rotation
Make a piece of wood with the motor mount bolt pattern holes in it with a rod sticking out where the prop shaft should be. Most of the time you can draw an X from the holes and get close to the shaft line. Then mount the wooden patttern where you want the muffler to line up and mark the holes.
