ORIGINAL: scooterinvegas
I've wondered the same thing. Using a Y cord, you would double the voltage and the mA would remain the same. The battery packs would have to be the same mA. And 2 - 4.8 battery packs in parallel would double the voltage to 9.6v. I think.
I too will wait for someone to say if its right or wrong. Scoot
Actually, putting the two packs in series would double the voltage. In parallel, as on a Y, the voltage would not change, the capacity would. If two packs were charged together that were not equally discharged, They probably would not charge evenly, one would either be undercharged or the other overcharged. If you post this in the batteries and chargers forum, there are some people over there that can explain it alot better than I can. But it general, I don't think it's a good plan.
