RCU Forums - View Single Post - Battery question
Old 11-20-2010 | 10:02 PM
Lnewqban's Avatar
Lnewqban
Default RE: Battery question
Copied from http://www.hangtimes.com/id33.html
"Parallel charging of Ni-Cds is not recommended due to the tendency of the cells to have the voltage drop off after they reach full charge."
"The use of redundant parallel fight packs (packs may be of different capacity but MUST be of an equal number of cells) is an excellent way to increase the available flight time and significantly improve the reliability of the on power system."
"Summary: Diodes are not required. Packs must be of the same number of cells. Packs may be of different capacities. Individual charge jacks must be provided for each pack (and not interconnected). Total capacity available will be the sum of the individual capacities. Specialized chargers are not required since standard packs (600-800 mAh AA packs)can be charged employing regular system wall chargers (1200 to 1600 mAh should cover most giant size projects)."
