RCU Forums - View Single Post - Redcat 8e Shocks???????
Old 11-21-2010 | 08:19 AM
formula87's Avatar
formula87
Default RE: Redcat 8e Shocks???????
ORIGINAL: Revolauncher
You need heavier springs to help against bottoming out. The Revo springs fit as do the Jato. RunRevo (front)greensprings up front and Revo (rear) white springs in the rear with 40 wt. oil. Mine has jumped a lot better ever since. A little stiff, but for big airit is great. Laying down your shock angle helps too, inner holes up top, outer holes on the arms, but you lose ride height unless you crankdown the preload collars on the shocks.
Het thanks, so you run a backdraft8e? my LHS stocks those springs so i will try that out thanks.
