RE: LT-40 and 4*60 Kit Bash
First pic is the wing saddle after I hacked it up with a dremel.
2nd pic shows the leading edge of the horizontal stab where I trimmed about 3/8" off in order to move the stab forward. I moved the stab forward so the hing line was even with the tail of the fuse.
3rd and 4th pics show the wing in the new saddle.
5th pic is the F2 former inside the fuse. Since the 4*60 wing was already built, and it had (2) 5/16" wood dowels sticking out the front, I had to make a hard ply mount. I cut this mount out of 1/8" hard play after taking a few measurements. Drilled the holes to line up with the dowels in the wing. Sanded the plywood mount to fit snugly in front of the F2 former. Checked for fit and then used some 6 minute epoxy to secure it in place.
