RE: Three bladed props vs. two bladed props.
The reason for a 3 bladed prop IS ground clearance.
A two blade prop is the way to go if you have the ground clearance, the three blade props are more expensive, harder to balance, have less selection and knowledge of which engine airplane combos work best.
