RE: Three bladed props vs. two bladed props.
The only reason a three bladed prop may be less efficient is that there is an extra prop tip, but usually the tip speed is less so often there may be no loss in efficiency. The reasons to use one in our models is that it should lower prop noise, more ground clearance, better high speed thurst (if you use a higer pitch), and on most models they look cool or scale like.
