RCU Forums - View Single Post - Another Skymaster Viper bites the dust....
Old 11-22-2010 | 11:15 AM
dubd's Avatar
dubd
Default RE: Another Skymaster Viper bites the dust....
ORIGINAL: highhorse
ORIGINAL: dubd
The wind was coming from right to left and it appeared you were pulling out of the loop with the plane coming towards you. Perhaps a stall occurred because there wasn't enough lift over the wings since you were flying perpendicular to the wind direction? Do you recall how much power you were giving at the top of the loop?
A very unfotunate loss, to be sure. But this isn't the cause.
Once an a/c has broken ground, steady state winds have no effect on airspeed whatsoever, and airspeed does not change simply because one is flying upwind, downwind, crosswind, or even when alternating between any combinations of the above.
I know that someone here will absolutely insist upon arguing and perpetuating the whole ''downwind turn'' myth. Please don't hijack this thread. I will start another for that.
I never said the model crashed because he was flying downwind, nor did I say that airspeed changed. I was "asking" if there was less lift on the wings when flying perpendicular in the loop. If you're going to prove me wrong (and I never said I was right), at least get my statements straight.
