RE: Engine sagggs ..............
Your comments re easy start indicate to me that the low end needle is pretty much OK
Since both engines exhibit the same symptoms, I'm tempted to look at the installation or other common causes.
Is it possible the airflow and subsequent cooling is lacking?
You would get these symptoms on an engine that is overheating
