RCU Forums - View Single Post - Downwind turn Myth
Old 11-23-2010 | 12:26 AM
  #162
Lownverted's Avatar
Lownverted
Default RE: Downwind turn Myth
ORIGINAL: p51Dpony
Seriously, explain to me this scenario:
.40 size trainer flying into the wind and you pull up, with all that available airflow it loops easily. ok.
Now fly with the wind in say 20mph, pull up for a loop, notice how the plane has trouble, slows down and has troubles at the top of the loop, on occasion not even making it to inverted but hanging on the prop and then nosing forward either with the wind or towards gravity. The issues at play again are drag and the airplanes non symmetrical design comparing front to back and how the machine behaves when the wind hits it from either the front or back. The described situation plays out in slope soarers often too as I recall.
Pretty simple really.
You expect your downwind loop to "look" the same as your upwind loop with the same control inputs. It can't! If it does, then you are making corrections and the inputs arent really the same are they? The mass of air it is flying within is moving, so by default it can't look the same with the same control inputs. By trying to make it look the same, you are flying it differently upwind than downwind. Your .40 size trainer sees EXACTLY the same airspeed no matter what the wind is doing. YOU see a difference, but the plane doesn't.
It's all about your perspective from the ground, the way the plane "looks". If there were a way to program your control inputs for a loop with the flip of the switch, you could easily see this by simply flying one loop upwind and one down. The loops would look quite different in shape to you on the ground, but the plane (or a person in the plane) would see/feel exactly the same. The plane doesn't care about wind, YOU do on the ground by trying to make it look the same!
Many folks here are confusing what the airplane sees (IAS) and what you see (GS). These folks just wont get it no matter what.
