RCU Forums - View Single Post - need help with diesel rc engine!! help asap!!
Old 11-23-2010 | 12:34 AM
  #65
AndyW
Default RE: need help with diesel rc engine!! help asap!!
And this might illustrate all my points. http://www.youtube.com/watch?v=zkNb6...eature=channel A traditional diesel starting, using a starter, no adjustments to the compression OR the main needle and utilizing a high ether prime.
Later work showed that the PAW would light off first try and keep running if the engine were heated to near running temps with a heat gun.
That's a lot of struggle to get an engine running but WITH ether in the fuel, this PAW will start with the starter, first crack, without the need to play with the compression or main needle.
