RCU Forums - View Single Post - Downwind turn Myth
Old 11-23-2010 | 08:18 AM
  #171
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Downwind turn Myth
ORIGINAL: p51Dpony
Seriously, explain to me this scenario:
.40 size trainer flying into the wind and you pull up, with all that available airflow it loops easily. ok.
Now fly with the wind in say 20mph, pull up for a loop, notice how the plane has trouble, slows down and has troubles at the top of the loop, on occasion not even making it to inverted but hanging on the prop and then nosing forward either with the wind or towards gravity. The issues at play again are drag and the airplanes non symmetrical design comparing front to back and how the machine behaves when the wind hits it from either the front or back. The described situation plays out in slope soarers often too as I recall.
You are desciribing the apparent ground speed not the airspeed of the plane. The plane is simply slowing relative to the ground and you are interpreting that as being at or near a stall. It is actually not having any more trouble, if handle the controls the same the result will be an egg shaped loop instead of a round loop. If there is any trouble it would be when flying into the wind and you back off the trottle at the top to slow it down so that the loop is rounder. Because you slowed it down you may enter an inverted stall and spin.
