RCU Forums - View Single Post - Three bladed props vs. two bladed props.
Old 11-23-2010 | 08:34 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Three bladed props vs. two bladed props.
ORIGINAL: jay1st
I meant for us, RC guys, not full scale.
Well if you are trying to set speed records then it may only be possible with a multi blade prop with a high prop pitch. But probably not a factor at the lower speeds of pylon racing. Some pattern planes use three bladed props to pass the maximum noise rule. The only factor that is not a benifit to our models is that a mulit bladed prop performs better at high altitiude.
