RCU Forums - View Single Post - Whats the best type bit to drill through balsa blocks?
Old 11-23-2010 | 02:14 PM
MTK
Default RE: Whats the best type bit to drill through balsa blocks?
ORIGINAL: bps
Kinda hard to chuck 5/8'' brass tube into a 3/8'' drill chuck....
You can make yourself an entire set of balsa bits using brass tubes. I use dowel rods inside and turn or sand one end down to fit my drill press chuck. Simple, cheap and works great.
<br type=''_moz'' />
[/quote]
No, it isn't hard at all to chuck up the brass tube. As this responder has found out, hardwood dowels make a simple stem. Epoxy in place and voila. For balsa, I've filed a saw tooth pattern on the edge of the tube.
Fostner bits are possibly simpler and readily available at hardware stores, so that a great approach. But in a pinch, when you need something right now, you can create the tool yourself
