RE: Whats the best type bit to drill through balsa blocks?
Use a Forstner bit definately. If you start with a new one, balsa will not dull it much. Also, drilla small pilot hole first, then the forstner eill follow it. Do not drill all the way through. Flip your pice over and finish from the other side. This will eliminate tear out.
