ORIGINAL: Bax
Basically, downthrust or sidethrust is used to reduce trim changes when the throttle is moved. If the airplane tends to go nose-up when the throttle is increased, then downthrust is added. The same if the airplane yaws when the throttle is applied. Ideally, you want the model to have a little pitch or yaw change as possible when the throttle moved.
Two full-size aircraft that had downthrust and side thrust are the Aircoupe (or Ercoupedepending upon the maker), and the Beechcraft Bonanza. Stand 'way back, and you can see it!
I'm a pilot and I've never noticed it on the Beechcraft Bonanza, of course I wasn't looking for it at the times I was around that aircraft.
Thanks Bax!
Oh by the way, can you tell your bosses that I want to see the O.S. 91FX Ringed come back? It was a fine engine.
Pete
