RCU Forums - View Single Post - Right Angle, Down Thrust?
Old 11-23-2010 | 07:46 PM
rye
My Feedback: (10)
Default RE: Right Angle, Down Thrust?
hi
my citabra usa balsa calls for 1% down and 1% right if i use washer to get this do i put one washer under each top and one on these on the left bottom or should i put two on the left side top ? this plane calls for a 120 4 stroke at the high end so we are using a dle -20 gas engine should i use more then 1 % on both thanks rye
