RE: XYZ 50 Problem
Donald,
It seems to be happening when the torque demand is high (rpm low), the throttle is full open (Venturi effect poor), but the low pressure in the crankcase is marginal and the nose is pointing up; which are the worst working conditions for the pump in the carb.
Replace the flexible parts of the carb if they may be aged.
Best luck with that!
