ORIGINAL: STKNRUD
I put one together about a year ago and remember I had the same problem you did with two of the wing mounting bolts. I don't remember having the others except that I did have to add a good amount of Hysol to a number of locations...not too unusual for China. Some of the Kindel linkage didn't fit and ended-up making some of my own.
Keep everything you possibly can aft. Even with that, you will most likely have to add a lot of weight to the nose. Besides additional weight, on many landings the fork will compress (ProLink gear) to the point it hits the asphal.[&o]
You mean keep everything forward .How much weight did you add ?
