RCU Forums - View Single Post - FiberClassics MIG29
Old 11-25-2010 | 08:02 PM
LGM Graphix's Avatar
LGM Graphix
My Feedback: (22)
Default RE: FiberClassics MIG29
ORIGINAL: Plautos
The main frame for the nose gear came glued out of position, it is not aligned with the fuselage….
Anyway, Otavio has lots of work ahead…
We will keep following your posts.
Plautos
Yes, this one was the same, the former is very crooked, I glued some plywood to the nose gear retract mount and sanded it until the gear sat correctly. None of the holes for mounting the nose gear were drilled (which was a pain in the butt let me tell you) so at least I could do some aligning myself, but the former was crooked enough that without shimming the gear it would not retract into the fuse.
