RE: engine quits after half throttle
WHen he had the initial problem the engine could have been seizing and the piston ring now stuck and damage to the cylinder. They will at times start cold and get worse with heat. IF this is the problem it could have caused by poor oil mix or too lean of a throttle setting.
