ORIGINAL: MTK
Here's the RECIPE that BOB and MATT have created (with bits of added info from few other sources) for the care and feeding of the SAP 180 with some additional inclusions to Bob's original post #877
1) [link=http://www.syssaaircraft.com/cart/pc/viewCategories.asp?idCategory=11]SAP-180HP engine[/link], 87-89 octane pump gas (10% ethanol), [link=http://www.syntheticoildistributor.com/amsoil_2cycle_oil.html]AMSoil Saber Pro[/link] 85:1 (after break-in with dino oil)
2) Another excellent synthetic oil you may use is BelRay MC-1 motorcycle oil mixeed 50:1. This oil may be used from initial runs to everyday
3) [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ646&P=7]Macs tuned pipe header for OS 1.40RX[/link], available from Tower Hobbies. The mounting holes need drilled to M5 size and recessed to fit the bolt heads and washers
4) Per Hoffman, NordLock washers under the bolts hold the header secure. This is a standard McMaster Carr item(We have had some trouble securing the header on the exhaust long term and NordLocks are touted to help). Another approach to holding the header on is to use Locktite threadlocker (per Todd Syssa) on the bolt threads. Removal of the locked bolts requires heat up with a soldering iron first
5) [link=http://www.escomposites.com/petrol.htm]ES 30G or 40G tuned pipe[/link]from escomposites.com. We install a couple button head screws on the stem to keep the couplers on. Either 2-56 or 4-40 X 1/8'' work fine; see item 8. The distance needed from the spark plug to the baffle inside the pipe is 27'' minimum, measured in straight line. We are currently running our set-ups with a distance at 28''. Matt has run to a distance of 30'' with very little performance difference noted
6) [link=http://www.siliconehose.com/commerce/ccp11370-870id4-ply-silicone-saej20-compliantgl-c40-087.htm]Silicone turbo hose[/link] from siliconehose.com, 0.870'' ID, rated SAE J20 R1, for the coupler, and also Matt (MTK) has had great success with [link=http://www.mcmaster.com/#5033k43/=7gklvt]Teflon tube coupler[/link] material from McMaster-Carr. Use standard nylon zip ties to secure the silicone turbo hose, and [link=http://www.mcmaster.com/#spring-hose-clamps/=7gloj1]wide-band spring hose clamps[/link] (Part # 7329K15) for securing the Teflon tube. The wire spring clamp is also used successfully and is what Matt currently uses to hold the teflon coupler
7) Use a [link=http://www.rcuniverse.com/forum/m_9237216/anchors_9687199/mpage_31/key_/anchor/tm.htm#9687199]1-inch long piece of 0.875'' OD aluminum tube[/link] as a spacer between the header and the pipe to minimize direct exposure of the turbo hose to exhaust gases. If you use the teflon material as coupler, the aluminum spacer is not necessary and in fact may cause you grief because it will slide inside the teflon tube. The ally spacer is a great idea only for the silicone turbo hose to keep hot exhaust gas internal exposure to a minimum
8) Place [link=http://www.rcuniverse.com/forum/fb.asp?m=9694367]3 or 4 buttonhead screws[/link] near the end of the header and the ES pipe to prevent the hose from sliding off. A couple of zip ties on each end will secure it solidly.
9) The engine can be hard mounted, but for pattern you will probably want to use a [link=http://www.rcuniverse.com/forum/fb.asp?m=9393393]soft 'isolator' mount[/link], making your own as described in [link=http://www.rcuniverse.com/forum/m_6285026/tm.htm]this thread[/link] by MTK. I'm fairly certain that Merle Hyde would be happy to make a soft mount, using the stand-off bolt template supplied with the engine. The Hyde mount will cost about 200$ based on work Hyde has done with the ZDZ40cc mounts. The noise difference is substantial between hard mounting and soft mounting an engine....airframe and radio high freq vibration difference is also substantial
9a) Intake noise is considerable eventhough the intake is rear mounted. Matt uses a simple block of very open cell sponge from Home Depot to help reduce some of the intake noise. It's the type orf sponge material used for drywall sponging
10) [link=http://www.rcuniverse.com/forum/fb.asp?m=9607516]Nose ring[/link] and [link=http://www.rcuniverse.com/forum/fb.asp?m=9599410]Static nipple[/link] on the carb ambient pressure reference plate. Eliminates inconsistent engine runs caused by pressure changes inside the cowl.
11) [link=http://www.apcprop.com/ProductDetails.asp?ProductCode=LP15512W]APC 15.5x12W prop[/link] (break-in with something with less pitch). I have tried a bunch of props and there is something magical about this prop with this set-up. The standard APC 16x12 pattern is almost as good, and an acceptable substitue if you can't get the 15.5x12W, which I got from Gravesrc.com
12) We have also used successfully the 18.1x10 apc, 17x10 apc, and 17x12 apc. The 17x12 that Matt uses allows lower rpm than the 15.5x12 Bob uses, but works well in a 10 1/2 pound pattern plane for noise and constant speed. It is the lowest noise set-up we have tried. The point is they both work well depending on what you want out of the package. The 18.1x10 and 17x10 are lower load overall (noisier too) and are good choices for break in.
Matt has tried the 15.75x11 3 blade (courtesy of Dave Lockhart). Matt's engine worked well on this prop but Temptress less well with it. The 3 blade repitched to 10'' had been tried before with the webra up front but it didn't work well then either.
13) Also recommended (to keep things light) is a [link=http://www.syssaaircraft.com/cart/pc/viewPrd.asp?idproduct=35&idcategory=11]Syssa (Tech-Aero) Ultra IBEC[/link] , which eliminates the need for a separate igntion battery and switch, saving about 5 ounces of weight (HUGE!), as well as optical kill switch, all controlled from the Tx.
14) Bob is also using a [link=http://www.tech-aero.net/plr5-i]Tech-Aero Designs switch/regulator[/link] for the Rx, with a Fromeco Li-Ion 2600 mah, but with the proliferation of LiFe batteries one could use one of these with no regulator. We like the Tech-Aero reg because it has a fail-on switch, so even with a LiFe I might use the Tech-Aero switch/reg for this feature alone.
15) Matt uses a single regulator and a single 1780 Lipo airborne battery. Point is one has several choices in regard to airborne battery set-up. Both Bob and Matt see similar current draw requirements per flight of about 200 mah per 15 minute flight
As we continue to develop the set-ups we will post findings here-in
Here are some more details:
1) On intake noise reduction- I removed the sponge foam insert. It tended to cause somewhat inconsistent running of the engine, possibly too restrictive.
2) Tried to fit an intake box but found it cumbersome in the tight quarters of my plane's nose. This was not actually run
3) Tried an intake manifold such at the type sold at Tower; didn't make much if any improvement to intake noise so I removed it, simplifying the set-up and allowing the use of the original choke baffle
4) Used Nitrile tubing from McMaster Carr for most of the season because of its flexibility. The tubing was removed recently and found to have lost some of its original properties.
5) I am now experimenting with very soft, polyurethane tubing inside the tank for about the past 2 months or so. Seems to be working well. Final answer won't happen until the Summer
6) Using Viton outside. Viton is a fluororubber and is untouched by gasoline, but it's a bit thick and inflexible. I'll see how this combination holds up over time and report here
7) Exhaust header security- we have found that Nordlock washers work extremely well and allow easy bolt removal. Found washers reusable.
8) I also lay a bead of Permatex Ultra Copper sealant in the exhaust flange joint.
9) Actually, an aluminum gasket is first fitted on the exhaust flange (cut from either gutter flashing or a simple soda pop can), and the Permatex is laid down on both sides of that. Leaks simply don't occur any more and the headers stay on. Tried it also without the gasket and saw some leaks, so I recommend the gasket.
The one thing I just can't seem to eliminate is the jump on pipe at around 4K. The low end needle has to be set slightly rich (about 1 3/16 turns) to allow the engine to operate reasonably at 6K (yup the LS needle really affects the mid-high end rpm considerably) and that slight richness seems to cause a little bogging down in transition when using the pipe. We probably still don't have the set-up just right yet. Just can't seem to get a smooth transition on piped set-up; I think a muffled set-up transitions better.
