RCU Forums - View Single Post - Scale Dynamics AT-6 Texan Build Thread
Old 11-26-2010 | 02:57 PM
mschneider2005's Avatar
mschneider2005
My Feedback: (34)
Default RE: Scale Dynamics AT-6 Texan Build Thread
The first step is to locate the center line of the center section and the main spar. Once you've done that, you mark and cut the notches in the foam for the gear mounting blocks.
While I had the hotknife out I recessed two basswood servo mounting sticks for the flap servo. They will be under the sheeting so they are flush with the top of the foam core.
