RE: Running Servo Wires through wing??
Buy some of the beaded chain that is used on pull/pull ceiling lights. It's the little brass ball stuff. You can get it at any hardware store. Stand the wing on end, insert the chain and shake a little. The chain will find it's way through the wing rib holes . Tie the servo lead on and pull it back through. This chain makes the job very easy.
